LTI individual throttle bodies? EXTRUDABODY ITB FOR SBC?
i was wondering if anyone has ever built a individual throttle bodies setup for the lt1, if you have would you be able to give me a link to it?
and if not i was wondering if it be possible to fab up a mounting plate the bolts to the heads with fuel injector ports, then weld on these intake runners from a Edelbrock Pro-Flow LS1 intake on then https://ls1tech.com/forums/attachmen...eenshot274.jpg, weld on plates on each runner like this
https://ls1tech.com/forums/attachmen...eenshot288.jpg, ill put the link to the itb for a ls1 i got my inspiration from:
https://ls1tech.com/forums/fueling-i...tb-fab-up.html
and does anyone know about these for chevy small block will they fit on a lt1http://www.extrudabody.biz/servlet/the-238/Chevy-SBC-X-dsh-Ram-Kit/Detail
What you are thinking of is simmilar to hilborn EFI setups. http://www.hilborninjection.com/category.asp?Id=255
Very trick stuff and cool as hell looking and to think about. They have a weber style setup that is fuel injection as well as several others. Don't know how well they run but cool none the less.
OWN3D BY MY PROF!
I've thought about it a couple times using an LT1 intake manifold with added dividers in the middle. Then, using 4 stock LT1 throttle bodies. It's a little different, but it would be interesting. There was a thread on an Impala forum that I can't find any longer where a guy used two LT1 throttle bodies on a stock intake manifold with a custom top piece.
