Tcc Lock Up Help
Tcc Lock Up Help
The input shaft drum that has the check ball in the drum itself(4L/60E), I heard that if you remove it; it will firm up the TCC lock up. If that is true how much difference will it make? Do any of you tranny pros think it's a good idea?
If you still have the PWM converter regulator valve, try changing that out for the non-pwm set-up first (a couple of companies make them). It can be done without tearing down the entire tranny (drop the pan), and may accomplish what you want.
