Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
- Camaro and Firebird: Torque Specs and Information for Installing Clutch and Flywheel
Important information to help you understand your Camaro or Firebird
Torque Specs Clutch/Flywheel
No, however I strongly reccomend using new flywheel bolts every time
At the very least when re using flywheel bolts I add a 4th torque rating to be sure the old bolts do not break. However you can clearly see the bolt distortion to the edge of the bolt
Flywheel : 18ftlb - 36ftlb - 52ftlb - 74ftlb
