Old 01-27-2004, 12:35 PM
mean02's Avatar
Default 11.25:1
how would a 100 shot be with stock bottom end with this compression?
Old 01-27-2004, 12:57 PM
Big Mike's Avatar
No problem there!!!
First, a 100 shot is not a big shot. Second, compression doesn't effect nitrous or vice versa. Just make sure your fuel is up to par and you'll be fine.
Old 01-28-2004, 08:01 AM
mean02's Avatar
thanks mike, anyone else?
Old 01-28-2004, 08:50 PM
GC99TA's Avatar
Yeah, what Mike said. Contrary to popular belief, nitrous can work great on a high compression motor. Higher compression ratios can raise combustion chamber temps, which can lead to detonation, but as long as you have adequate fuel delivery and a conservative amount of ignition timing, you should be fine with a 100hp shot.
