max cam duration on a stock 02 ls1 engine
Old 09-17-2010, 06:23 PM
02_Firehawk's Avatar
Default max cam duration on a stock 02 ls1 engine
anybody kno what is the maxium camd duration on a stock ls1 engine i have a 02 firehawk...
Old 09-17-2010, 06:31 PM
camz28arro's Avatar
The Ms4 is pretty much the biggest cam you could put in.
239/242 .649"/.609" 111
Old 09-17-2010, 06:43 PM
so im ok with the
LS1 Comp Cams LSR Cathedral Port Cam (243/251 114LSA) 5.7L-6.2L
(Int. 243 Ext. 251 Lift Int. .624 Exh. .624 LSA 114°)
Old 09-17-2010, 06:56 PM
The_Rizzle's Avatar
Why...? what application?
Old 09-17-2010, 08:36 PM
KevinR's Avatar
The Trex is a bit bigger on the duration that the Ms4 and people are fine running that.
.242 .248
.251 on the exhaust side is pretty steep. What heads are you running?
Old 09-17-2010, 09:11 PM
SweetS10V8's Avatar
Originally Posted by 02_Firehawk
so im ok with the
No, you have to check pistont to valve clearance for yourself. Dont rely on some random guy on the forum. If your engine kills itself no one is going to cut you a check to repair your engine.
Old 09-17-2010, 09:18 PM
BillyBob750's Avatar
Stock cylinder heads? With, or without flycutting?
Old 09-17-2010, 10:02 PM
stock cylinder heads
Old 09-17-2010, 10:04 PM
smg267's Avatar
CHECK SIG FOR MAX NUMBER OF CAMS!!
Old 09-18-2010, 06:45 AM
KevinR's Avatar
Then no, it won't work.
Old 09-18-2010, 09:10 AM
vettenuts's Avatar
All of the above mentioned cams fall below the PTV minimums.
Quick Reply: max cam duration on a stock 02 ls1 engine
