max cam duration on a stock 02 ls1 engine
Old Sep 17, 2010 | 06:23 PM
02_Firehawk's Avatar
Default max cam duration on a stock 02 ls1 engine
anybody kno what is the maxium camd duration on a stock ls1 engine i have a 02 firehawk...
Old Sep 17, 2010 | 06:31 PM
camz28arro's Avatar
The Ms4 is pretty much the biggest cam you could put in.
239/242 .649"/.609" 111
Old Sep 17, 2010 | 06:43 PM
so im ok with the
LS1 Comp Cams LSR Cathedral Port Cam (243/251 114LSA) 5.7L-6.2L
(Int. 243 Ext. 251 Lift Int. .624 Exh. .624 LSA 114°)
Old Sep 17, 2010 | 06:56 PM
The_Rizzle's Avatar
Why...? what application?
Old Sep 17, 2010 | 08:36 PM
KevinR's Avatar
The Trex is a bit bigger on the duration that the Ms4 and people are fine running that.
.242 .248
.251 on the exhaust side is pretty steep. What heads are you running?
Old Sep 17, 2010 | 09:11 PM
SweetS10V8's Avatar
Originally Posted by 02_Firehawk
so im ok with the
No, you have to check pistont to valve clearance for yourself. Dont rely on some random guy on the forum. If your engine kills itself no one is going to cut you a check to repair your engine.
Old Sep 17, 2010 | 09:18 PM
BillyBob750's Avatar
Stock cylinder heads? With, or without flycutting?
Old Sep 17, 2010 | 10:02 PM
stock cylinder heads
Old Sep 17, 2010 | 10:04 PM
smg267's Avatar
CHECK SIG FOR MAX NUMBER OF CAMS!!
Old Sep 18, 2010 | 06:45 AM
KevinR's Avatar
Then no, it won't work.
Old Sep 18, 2010 | 09:10 AM
vettenuts's Avatar
All of the above mentioned cams fall below the PTV minimums.
