what plugs do I need?
I have a set of AFR 210 heads for my 383 lt1 build. I am currently running a stock style plug and the tuner recommended NGK TR6 plugs. I was looking on AFR's website because a friend said he thinks I needed sbc plugs with the metal gasket and they say to use plugs with a gasket. Am I using the wrong plugs? Did the tuner recommend the wrong plugs as well? I would like to change the plugs now but unless I find out more I have to wait until Monday and talk with someone at AFR.
http://www.airflowresearch.com/sbc_install.php
Your heads and most aftermarket heads are mchined for a gasketed plug. So, yes you need the gasketed version of the TR6.
Look at Summit or Jegs. Aftermarket also need a longer reach plug.
Something like this might work
http://www.summitracing.com/parts/NGK-2756/
I was told I need a hot plug any recommendations. I am running low compression
96 383 stroker motor
4 bolt splay
Lunati crank
Oliver I beam rods
je inverted dish pistons (reason for the low compression)
comp cam 290 hr-12
comp cam promag roller rockers 1.6
AFR 210 heads
2500 stall
BBK 58mm throttle body
lt4 intake port matched
pacesetter long tube headers
off road Y-pipe
flow masters
4 bolt splay
Lunati crank
Oliver I beam rods
comp cam 290 hr-12
AFR 210 heads
2500 stall
off road Y-pipe
flow masters
