what plugs do I need?
http://www.airflowresearch.com/sbc_install.php
Look at Summit or Jegs. Aftermarket also need a longer reach plug.
Something like this might work
http://www.summitracing.com/parts/NGK-2756/
96 383 stroker motor
4 bolt splay
Lunati crank
Oliver I beam rods
je inverted dish pistons (reason for the low compression)
comp cam 290 hr-12
comp cam promag roller rockers 1.6
AFR 210 heads
2500 stall
BBK 58mm throttle body
lt4 intake port matched
pacesetter long tube headers
off road Y-pipe
flow masters
