Zr1s on 3rd gen Camaro
Youll need to buy wheel adapters approximately 2inch all around.
You also have an alternative. You can swap rear ends, example throwing in a LS1 rear end with disk brakes and it bolts up like nothing, and you would only have to buy 2 2 inch wheel adapters for the fronts.
my buddy has an 87 iroc z. he went with 1 1/2 wheel in adapter and 2 out back. the front wheel rubs with the sway bar thats right there. If he goes 2 inch, the problem goes away.
he has 18x9.5 fronts and 19x10 out back.
