Sway Bar or Adj. PHB??
Old 01-28-2004, 09:14 AM
00NBMCamaro's Avatar
Question Sway Bar or Adj. PHB??
considering getting one of the two along with some plugs and wires... which would be more fun with my set up.. im thinking sway bar.. the 1le bar..
i have eibachs, 17 X 10 wheels with 275's on them, bilsteins, SFC, LCA's and STB..car is a 2000.
the sway bar would only be the front one BTW.. and PHB i dont think is needed cause my axle is centered.. anyways i want both sooner or later but only buying one at a time... also where is teh ebst and cheapest place to get these parts..
and what would the advese effects be to having a 32 MM front sway bar and stock on the back..
thanks
Old 01-28-2004, 07:51 PM
locosteelersfan's Avatar
sent you a PM
Old 01-28-2004, 07:54 PM
Also staying stock in the rear is fine, actually most
of the time advised. At most go with a 1le rear.
I don't know of any cons to buying a front up to 35mm
