LM7 W/LS1 Heads
Old 09-28-2010, 11:37 PM
hcb1700's Avatar
Default LM7 W/LS1 Heads
I just want to know if it would be worth swapping the stock LM7('00) heads for some LS1('01) heads since they have bigger valves? My brother did a heads and cam swap on his Z28 and these parts are just laying there. Would they work/fit without any problems? Don't the LS1 heads have smaller combustion chambers, therefore giving a slightly higher compression ratio? I'm looking into swapping this engine into my '78 Z28 and need to know this before I drop it in.
Old 09-29-2010, 09:38 AM
chevyboy91188's Avatar
Ls1 has bigger chambers, don't know where you heard they are smaller? Think about this, ls1 is a bigger engine and compression ratio is what? Like 10.5 to 1, the 5.3 is smaller and its cr is 9.5 to 1 those are pretty close especially considering the ls1 has flat tops and the 5.3 dished pistons. The heads almost flow the same too. A common upgrade on ls1 is getting 5.3 ported and have bigger valves put in them. Really no one wants ls1 heads unless they have the l33 like me which has 9.9 cr due to flat tops in this model, and I would only need them to lower my cr so I could use forced induction.
Old 09-30-2010, 02:48 PM
deuce4935's Avatar
What I did was took the ls1 valves and installed them on the 5.3 heads, had them ported and polished along with a spring upgrade.
Old 09-30-2010, 09:46 PM
hcb1700's Avatar
What cam are you running?
Old 10-01-2010, 09:55 AM
deuce4935's Avatar
A Comp custom grind with low .600" lift.
Quick Reply: LM7 W/LS1 Heads
