which goes to ground and which goes to battery on starter?
Old 10-02-2010, 11:15 AM
Marcello7x's Avatar
Default which goes to ground and which goes to battery on starter?
Which one of these is ground and which goes to the battery. I already know the smaller one is the keyed signal..
Old 10-02-2010, 11:32 AM
94'BLKBRD's Avatar
I believe left is power/positive and right is ground/negative.
Old 10-02-2010, 03:08 PM
That's MISTER MODERATOR
Paul Bell's Avatar
There is no ground connection at the starter. The battery positive goes to the big stud that's on the left. The one on the right is the solonoid connection to the starter motor.
The ground is made by the starter being bolted to the engine.
If you connect ground to the right terminal, everything will blow up when the key is turned to "start".
Old 10-02-2010, 06:16 PM
Marcello7x's Avatar
Ok makes sense.
Is it ok to use the larger stud as a terminal to split off to the alternator from.
Old 10-02-2010, 07:02 PM
Paul Bell's Avatar
Yes, that's usually how it's done when the battery is removed from the engine compartment.
