crank or cam sensor problems?
Old 10-07-2010, 07:08 PM
TurboChris's Avatar
Default crank or cam sensor problems?
Do the LS-type engines have cam or crank sensor problems, and if they do, what symptoms, for each one?
Thanks, Chris
Old 10-07-2010, 07:42 PM
garygnu's Avatar
yes they do .if a crank sensor is bad ,it won't start.if the cam sensor is bad no tach reading.IIRC.check all you ground straps .
Old 10-08-2010, 03:13 AM
TurboChris's Avatar
Thanks, I'll check my ground. Tach on DFI screen does intermitttently jump, could be cam sensor, as you said. Thanks again.
Quick Reply: crank or cam sensor problems?
