Best oil pump..
Old 10-10-2010, 03:49 PM
kmspruill242's Avatar
Default Best oil pump..
I've got an LS6 long block ready to go into the WS6. I road race this car so I'm trying to give this thing as much help on the oiling side of things as possible. Problem is there are too many oil pumps to choose from .
Then theres the problem of high volume vs high pressure.
So what do you guys think? Moroso, Melling, Scoogin Dickie? High volume, high pressure?
Old 10-11-2010, 03:40 PM
I'm guessing the stock pump is more than enough then?
Old 10-11-2010, 06:11 PM
RARON455's Avatar
Melling 10296 you can choose which spring you want to use with this pump also.
Old 10-11-2010, 08:06 PM
Big Bu Bu's Avatar
Go with the Katech blueprinted LS oil pump. They know the LS better than anyone for road racing. They use this pump on the C5R factory road racer.
http://katechengines.com/katech_inc/...g/oil-pump.htm
