Stand Alone Wire Harness
I'm trying to save some cash by setting up my own stand alone wire harness for an LS2.
I have the entire 06 GTO engine harness w/ecm and the entire Cabin harness with the accelerator pedal and even the guage cluster(not needed).
Does anyone have a good schematic to build one with?
Or at the least know of someone that will modify mine at a LOW COST?
I'm having trouble sorting out the passive security system and all I want is the cruise control and throttle. Everything else can be cut off that's not required to RUN this bad boy.
Thanx!!
Thanx!!
I suscribed @ www.alldatadiy.com, and used the info there to do the harness from my 05 Hummer.
It's all printable..Has alot of other good info, too.
I think I paid about $35.00/yr.
Check your PM for schematic info or I can re-work your harness for a very reasonable cost.
Harness rework includes removing all unnecesary wires for your application, adding OBD2 port, check engine light, inline fuses, relays for main power, fuel pump, dual fans and TCC if automatic trans. Replacing minor damaged connectors. I label all input and output wires for easy installation.
