Question about 19'' on a 00 Z28
Depends on the offset, width of the rims, and what series tire you go with. It's definitely been done, and with the correct aforementioned info , they should be good to go. There's lots of threads on here about people with 19's, some had to do work, others just bolted them on. A search will turn up tons of results.
-Brandon.
-Brandon.
you can see the offsets that will fit your car here :
https://ls1tech.com/forums/wheels-ti...must-read.html
you might need to run spacers for some offsets and do the BFH mod if you put too wide tires , but other than that , you shouldnt have any problems
