LS1 dash/gauge cluster what gauges can I use?
Ive swapped an LS1 TA dash into my thirdgen and im lloking to find out if and how can I use the tach, coolant temp and oil pressure gauges from the LS1 cluster. I have an LT1 with the EFI connection setup so I do have the LS1 PCM but I dont have the BCM....
if your useing the ls1 pcm and harness they should work fine. i used a v6 camaro cluster (o1 i think) in my mustang and the tach,coolant temp, speedo and volts are all form one wire and the oil presure is another. but they all came straight from the pcm harness.
im doing a malibu now and im going to use a stock cluster andthis time i wanna see if i can get the fuel gauge to work too.
Sweet. What pin did you use on the pcm? I wonder if the v8 cluster is similar. Everything I have read says you can't use it without the bcm. Got and pics of the wires you used on the cluster?
