prc head question on hp gains
Old 10-21-2010, 09:33 PM
b20forlife's Avatar
Default prc head question on hp gains
hi everyone I have a completly stock internally ls1. now i want to add heads and cam. now I have a budget which isn't very much. now I'm looking at the prc either the 2.5 5.3 heads or the ls6 1.0 heads. which will yeild more power? I will have long tubes 7/8 and ls6 intake amd throttle body along with ms4 cam. this will be a track car that is driven every once in a while. thanks
Old 10-21-2010, 10:19 PM
garygnu's Avatar
get the ls6 stage 1 heads with a torquer 3 cam,it will average better power then the ms4.the ms4 needs a big stall or a great clutch and gears.the ms4 will have a very close piston to valve clearence,and probably require piston fly cutting.bigger dose not make faster.
Old 10-21-2010, 10:37 PM
b20forlife's Avatar
I have a t56 with spec stage 3+ clutch. now will the torquer v3 have more gains in hp on the stage 1 ls6 heads or the 2.5 5.3 heads
Old 10-22-2010, 09:28 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Both will do very well for you. I like the LS6 heads because they can be easily upgraded down the line if you decide to get crazy!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Quick Reply: prc head question on hp gains
