LM2 and HP Tuners
Old 10-29-2010, 04:45 PM
nick97ta's Avatar
Default LM2 and HP Tuners
Has anyone successfully hooked up the LM2 to the HP Tuners with out HP pro and buy using the A/C pressure switch?
Old 10-29-2010, 08:00 PM
MontecarloDrag's Avatar
You will need a good multimeter and a lot of patience...
Old 10-30-2010, 08:54 AM
badcoup's Avatar
I used the fuel tank pressure sensor it was really simple just use a good ground that also has one of pcm grounds so help eliminate a ground offset I compared the voltages displayed on the hp tuners and the innovate software. There's a good writeup on here somewhere
Old 10-30-2010, 10:14 AM
nick97ta's Avatar
I've got it setup in the a/c pressure switch, but I keep getting "unsupported parameter" when I start scanning.
The PID I have setup is ([PID.7101]/.33)+7.35
I think it's incorrect, but can't get any info to see if that's true. This is on a 06' GTO if that helps.
Quick Reply: LM2 and HP Tuners
