Is 4.31 TPS Voltage At WOT ok?
Old 11-03-2010, 05:28 PM
Pro Mouse's Avatar
Question Is 4.31 TPS Voltage At WOT ok?
On my 408 with with Open Loop only tune and 90mm TPIS TB.I had to trick my TPS sensor to open blade a little bit for Cold Starts.I drilled the tps holes bigger to get mobility to go the other direction of the tps mod.I made my TPS voltage at Idle .47 and zeroed it out.I got 100% at WOT But my TPS voltage it is 4.31 v using HPT scanner.Now the Car Starts great.Will 4.31 be ok for WOT Voltage? Before I did my TPS mod I had 4.47 v at wot...Thanks
Old 11-03-2010, 11:04 PM
THErobertH's Avatar
TPS signal should be at 4.5. i don't see 4.3 being much of a problem, a bit lower power than what it should be pushing. but no real problems.
Old 11-04-2010, 01:21 AM
93camaro_zzz's Avatar
You have a FAST intake? Make sure the Throttle blade is opening all the way. I heard the FAST's have problems with that sometimes.
