NEED HELP difference between ls6 ans ls2 wiring harness
This is assuming by LS6 harness you mean out of a vette and ditto on the LS2. The PCM connectors are different from those, so I assume you are using the computer for the LS6 harness. That would be the easiest way.
The LS6 harness will work. It does not care what engine it goes on as long as you make arrangements for it to use an LS2 vette/gto TB with a harness. I dont remember what the truck TB looks like or if it will work right with the car computer. At the moment I dont think so. You will have to use a converter box if the engine is a 58x because you are using a 24x computer from the vette. So just make sure on those. My sources say it is 24x if its an 06.
On the MAF, use what you want. The truck maf is 5 wire, so you can use an adapter harness for that to make it easy.
On the fuel injectors, they will be the LS2 style so you will need a fuel injector adapter harness.
Give me a shout if you are questionable about any of this or need any more info.
The 2006 GTO (and all GTOs) run a 24x wheel.
