fel pro intake gaskets?
Old 11-09-2010, 07:38 PM
Stingerrr85's Avatar
Default fel pro intake gaskets?
wat is the two foam pieces that i got wit my kit i got 8 rubber gaskets and 2 foam pieces were do they go
Old 11-09-2010, 07:57 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
on the under side of the intake, one front and one rear
Old 11-09-2010, 08:31 PM
bww3588's Avatar
when i ordered the intake gaskets, i didnt get rubber rings, i got an actual gasket.
Old 11-09-2010, 09:29 PM
sjsingle1's Avatar
i did not get any foam thingys
Old 11-09-2010, 10:19 PM
massls1guy's Avatar
I made my own from left over window AC insulation.
Old 11-10-2010, 08:34 AM
K thanks guys
Old 11-10-2010, 08:36 AM
Tobias05's Avatar
my foam did not want to stick, i had to talk sweet and glue them in.
Old 11-10-2010, 04:57 PM
Pocket's Avatar
You either got the big expensive ones for trucks (one piece plastic) or for alum intakes (cardboard with rubber ring injected on). The truck gaskets wont fit period and the paper style arent designed for plastic intakes and risk major vacuum leaks. Take it back and exchange it for the ring style (cheapest type actually)
Old 11-10-2010, 05:44 PM
bww3588's Avatar
It wasent the plastic truck gaskets, it was the paper style ones with rubber rings. That was over a year ago and it worked just fine.
Old 11-10-2010, 05:45 PM
bww3588's Avatar
They were like 11 bucks at autozone. No big deal.
