Jet Performance chips
Old 11-11-2010, 08:02 AM
Red06SS's Avatar
Default Jet Performance chips
Has anyone ever used one of these yet? Or is it just always better to opt for one of the tuners? I had a stage 1 for my 01 S10 Xtreme years back and always had good luck with it.
http://www.summitracing.com/parts/JET-10732S/
Old 11-11-2010, 10:49 AM
LS1 Racing's Avatar
I've never had much luck with "canned" tunes from JET, HyperTech, or even DiabloSport. They all seem to add a ton of timing without doing anything about fuelling, and it simply leads to a lot of KR and poor drivability.
After trying one of DiabloSport "91 octane tunes", I went back to stock and called Lew (06MonteSS) and had him do a mail-order tune. Made a HUGE difference.
Since you have an '07, I'm really not sure what your choices are, as the DiabloSport only works on the 06s.
Old 11-11-2010, 12:15 PM
monte_with_a_LS4's Avatar
yea the difference between the tunes that come on the tuners and lew's tune is a beg difference. I couldnt even tell a difference when i installed the 91 octane diablo tune
Old 11-11-2010, 02:30 PM
neilownz's Avatar
Vector would be an option if you can't get a custom tune.
Old 11-11-2010, 02:31 PM
LS1Tech Sponsor
06MonteSS's Avatar
stay away from JET anything... garbage and waste of money...
besides that, there are no "chips" for our vehicles - regardless of what that page tells ya... everything is flash-based tuning now... there's no adding a chip to the ecm...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 11-11-2010, 08:24 PM
neilownz's Avatar
The jet chip goes between the plug and the ecm and changes the signal.
Old 11-12-2010, 08:59 AM
LS1Tech Sponsor
06MonteSS's Avatar
really?? then I stand corrected... but damn, that's hokey... definitely wouldn't trust that, heh...
especially when it can be tuned much better, the CORRECT way, by flashing a tune to the ecm...
you have better choices out there for the '07's for sure... hp tuners, efilive, get it tuned correctly at a shop, etc etc...
what happens when that "chip" or its connections go bad?? heh...
Old 11-12-2010, 11:04 AM
Red06SS's Avatar
The connectors to the ecm and tcm are amazing on this car. By far the easiest ive ever had to monkey with. But, depending on what I do, might just hold off and wait as I am debating a turbo kit now.
If I sell my Chevelle, I might drop some serious coin into the 07 SS.
Old 11-12-2010, 12:09 PM
LS1 Racing's Avatar
Or, you could sell the SS and do an LS3 swap into your Chevelle!
Old 11-12-2010, 12:41 PM
BLKHAWK1's Avatar
There Powercal cable makes it really easy
http://www.vectormotorsports.com/ind...mart&Itemid=28
Old 11-12-2010, 12:43 PM
Red06SS's Avatar
The SS is rocking a 454 at the moment.
Old 11-12-2010, 01:29 PM
Ill_Born_ss's Avatar
BE VERY CAREFUL! if you are under warrenty... every time you disconnect these computers IT IS LOGGED IN THE BCM MEMORY and THEFT DETTERANT SYSTEM it can only be cleared by the TECH2
Old 11-12-2010, 01:40 PM
Red06SS's Avatar
It's ok, I have access to a tech2.
Quick Reply: Jet Performance chips
