T56 Input shaft swap question
leaving out that the ls1 t56 is longer are there any differences that would keep me from installing one into an LT1 case with LT1 mid plate.
The reason I am asking is I need a longer input shaft to reach the crank/clutch disc on my setup.
Yup, they will swap just fine. Just as long as you don't have the oddball 93' model T56 (M29). Both inputs should have 31 teeth. I *think* there's a 1.5 inch difference. I have 3/8in spacers available if you don't need quite that much (1.5in). It goes btw the bellhousing and front of the T56. Or, I can make you an input shaft at any length.
