what do i need to run a vic jr?
Old 11-23-2010, 07:25 AM
SS4Luck's Avatar
Default what do i need to run a vic jr?
I plan on running a vic jr with an accufab 4159 4 barrel TB on a SD tune.
i plan on trying 3 or 4 different setups with it as far is induction before the TB to see whatworks best. Ive been doing alot of reading on them and so car im at.
1) 45* carb hat to 1 or 2 filters in the front of the nose kinda like a sux2bu ram air setup
2) to a FTP 104/5 whatever it is MM lid, or hacking the **** out of my lid right now and figuring out a way to make a 110mm one or w/e size the tb is
3) fabbing n air cleaner and letting it sit ontop of the motor
I know i will need a lokar TB cable, but what about fuel rails? What about a map sensor.. where do those go with a vic setup?
this will be ontop of a MS4/PRC227 346 ci drag car that does get its fair share of street racing
Old 11-27-2010, 09:10 PM
Dmoney's Avatar
This is what I ordered:
Part #
29086 Vic Jr. w/ fuel rails
TC1000636 Lokar cable(cut to fit)
15152 Jegs throttle cable bracket
M592438 intake gaskets for Vic jr.
RGR501 fuel rail kit from Speed Inc.
9749 (2) 45* elbows
9849 Spectre carb hat
Take your Map sensor off you intake and the Victor Jr. will come with a bracket to mount the MAP sensor to the back bolt on top of the intake before you bolt on the throttle body and you just run a hose from the sensor to the intake...........
