How to do it? Bs3, 8 coils, and no factory style crank reluctor wheel.
Old 11-24-2010, 11:22 PM
lt1camaroman93's Avatar
Default How to do it? Bs3, 8 coils, and no factory style crank reluctor wheel.
Is there a way to ditch the factory style reluctor wheel, run an external crank trigger and then use the factory cam signal to fire all 8 coils using a bs3?
Old 11-24-2010, 11:42 PM
Texas_WS6's Avatar
Why ditch the factory reluctor wheel? And yes you could do this.
Old 11-25-2010, 09:09 AM
camarols1's Avatar
https://ls1tech.com/forums/new-products-showcase/1150673-virginia-speed-crank-trigger-bracket-ls-engines.html
Looks like Shawn whipped up a nice bracket for this application.
I was unable to find a wheel, but I am sure John at BS3 could help you out.
I checked into this before and I believe that some of the guys running higher RPM combos switch to the front mounted crank wheel for improved accuracy.
I wouldn't think it would take very much effort to set up.
Jim
Another option from Kurt Urban.
http://www.kurturbanperformance.com/...r-bracket.html
The MSD flying magnet wheel will require the BS3 box to be reset to operate off a 4x signal.
Old 11-25-2010, 01:13 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
J,
Andy is running an external crank sensor + running 8 coils with BS3.
Old 11-25-2010, 05:04 PM
For internal reasons. I just wasn't sure if you could use a normal msd crank trigger to give the bs3 the resolution needed, but sounds like we can! I'm a very happy man knowing this.
