Does leaning out fuel ratio with predator save gas milage?
Old 02-04-2004, 09:41 PM
WARNING: BAD TRADER STATUS
TWISTA TA's Avatar
Default Does leaning out fuel ratio with predator save gas milage?
I have kooks lt's with ory, msd wires, mac cat back, and a volant air intake. I was thinking about getting a predator and I was wondering how much can I lean out the fuel without problems, and can I save on gas milage to make up the cost of running premium over regular? Also do I have to run premium with a predator?
Old 02-04-2004, 09:51 PM
slow's Avatar
you have to run premium in these cars, with stock tuning.
10.1:1 compression ratio.
Ryan
Old 02-04-2004, 10:07 PM
TWISTA TA's Avatar
I never run premium and I have never had it ping.
Old 02-04-2004, 11:30 PM
NoGo's Avatar
You cannot make your car run any leaner with the Predator without throwing SES codes.
Old 02-05-2004, 03:47 PM
02redSS's Avatar
the PCM is in closed loop mood during normal operation so whatever you adjust will not affect your everyday milage. if it needs fuel to keep the correct a/f ratio, it will take it.
