Can an '02 Camaro LS1 long block bolt into '02 Trans Am
Old 11-28-2010, 02:14 PM
Nino222's Avatar
Default Can an '02 Camaro LS1 long block bolt into '02 Trans Am
Sorry for the nub question.
I'm selling a long block on e-bay from a '02 Camaro. The heads on the Camaro long block are 241 casting number with a surplus LS6 block from the factory. A guy with an 02 Trans Am wants to know if my LS1 can bolt into his Trans Am without major compatibility issues.
In other words, Is there a difference in the bolt patterns of the 2002 Camaro LS1 vs. a 2002 Trans Am LS1? My long block assembly comes with a harmonic balancer, valve covers and a T56 flywheel. Are these compatible too? I remember something about a middle bolt in the valve covers not being compatible.?.?.?
Thank you. Sorry I just don't know anything about Trans Ams.
Old 11-28-2010, 02:17 PM
MurderedOut's Avatar
same car.
nandos_z28's Avatar
Same exact thing. They'll swap no issues
Old 11-28-2010, 02:18 PM
Nino222's Avatar
This may need to be deleted and reposted in external engines. I didn't know if the valve covers were considered external or internal. I figured I'd have better luck with the compatibility issues of the heads with the people who frequent the Internal Engine section.
Old 11-28-2010, 02:19 PM
Nino222's Avatar
Holy fast. thanks guys...
Old 11-28-2010, 02:20 PM
180ls1's Avatar
yea they are identical.
Old 11-28-2010, 02:21 PM
robcas47's Avatar
Yes it will. As long as your buddies car is also a M6(six-speed) then there really isnt an issue.
Old 11-28-2010, 03:37 PM
caseypryan's Avatar
Really....?
Old 11-29-2010, 11:46 AM
slt200mph's Avatar
All 4th gen F body cars were built in the same factory...using the same engine...nuff said ..
Old 11-29-2010, 11:56 AM
freakyfastlsx's Avatar
yes will bolt right up
