Trans. Temp?????
I'm running a TCI 3800 with the B&M 24K GVW and after some in town driving and idling I get to around 183 or so in 70-75 degree weather. I haven't checked the temp after a long highway cruise. I was around 200 prior to the cooler.
Tim
Tim
LS1Tech Administrator
Received 1,794 Likes
Keep in mind when asking about or comparing trans temps, that if you are getting your trans temp readings from A-tap they will be higher than those from a regular trans temp gauge tapped into your pan.
