cam shoot out ls6
LS1Tech Premium Sponsor
we've dyno tested tons of camshafts on LS1 & LS6 setups. What are you looking at & we probably have a graph.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Will the stock injectors handle over 400 hp? Of course they will. Are they designed to handle this? Of course they aren't. Its all relevent here gentlemen, you start doing things stock parts are not designed to do and you are asking for trouble i.e. 10 bolt rear ends, stock clutches etc. etc. Its also not advisable to run an injector over 80% duty cycle. Now surely Josh you arent saying stock injectors can support 450 hp at or below 80% DC?
We could all likely run cam or H/C LS1s all day with stock injectors. But are we wanting our car's engines to be closer to the ragged edge or further. For me, I'd take the latter.
What size are 2000 injectors 26lbs? Im doing a cam only LS6 swap on a 2000 so i guess atleast i need to find some stock 28's
