crank sprocket removal?
I need some help removing my time sprocket and am not having any luck. its a rollmaster double roller timing set that is installed at the moment. I can see that there is a little pin installed but i am unable to remove it. after searching google I found i might need a 2 jaw puller to pull of the sprocket but i still need to remove the retaining pin. any one have any tips they can offer?
