Global west double bearing LCA's?
Old 02-06-2004, 05:12 PM
Revelation222's Avatar
Default Global west double bearing LCA's?
ANyone using the tubular GW LCA's with the Spherical aircraft bearings on both ends? How are they? Any issues? Thanks
Old 02-06-2004, 07:32 PM
Must keep this current...TTT
Old 02-06-2004, 09:34 PM
No one? Good lord. Guess I'll be the guinea pig.
Old 02-06-2004, 11:23 PM
2001CamaroGuy's Avatar
I have the BMRs and will never have anything but rod ends on my performance stuff.
Old 02-06-2004, 11:33 PM
Moderator
BADZ's Avatar
I have my own and so do half the ls1 world and they work perfect!!!!!!
Old 02-07-2004, 12:07 AM
You have the GW LCA's? No problems all all? Squeaking?
Old 02-07-2004, 01:31 AM
Moderator
BADZ's Avatar
non at all!!!
Old 02-07-2004, 02:35 AM
Judd's Avatar
I have the Global West single spherical LCAs. I do not like them. Mine throw out quite a bit of noise and you can't just replace the bearings like you can on "normal" rod ends.
If I could go back, I would buy a set of LG Motorsports adjustable aluminium LCAs. They have quality rod ends that will last quite a while before making noise. When they finally do start to make noise, you can just replace the ends.
Old 02-07-2004, 03:56 AM
mitchntx's Avatar
I've had LGM rod ends on my car for almost 2 years.
They are still tight and make no noise
Old 02-07-2004, 07:38 AM
Moderator
BADZ's Avatar
Default Lca's
I have my own desighn on my car not GW...Send me your email and I will so you...
Old 02-07-2004, 10:11 AM
Viper's Avatar
I had GW's back in 2000, hated them because of noise. Run LG's now.
Old 02-29-2004, 12:25 PM
Originally Posted by MarineSS
Rev'22,
Where abouts in SoCal are you? I'm always driving around to different parts of SoCal on the weekends. I have GW's double bearing LCA's on right now and they are noisy. I also have the Hotchkis double polys for most everyday driving. Depending on which style of race I am going to practice, I simply switch them. I've taken a few friends for a ride so they can hear for themselves. It really depends on how much tolerance you have for noise.
Actually, if you can see what makes the noise, you'd wonder why a narrower (is that a word?) housing for the bearing was not possible?
When you twist the arm between the the mounting brackets, it's the housing ends that bang back and forth between the mounting brackets on the body and axle ends.
The difference between the two types of LCAs are significant.
Im in LaCresenta, near Pasedena. I just ordered the Sphon Chrome moly Adjustable Dual Rod End LCA's (boy that was a mouth full) Hopefully, they work as good as they look. I never heard any bad things about them so I figured Id give them a shot. Road noise is fine, but loud cluncks are what Im worried about. However, if you are in tghe area sometime, look me up I still wouldnt mind hearing the difference between the two.
Quick Reply: Global west double bearing LCA's?
