window switches
Old 02-07-2004, 11:10 AM
exodus's Avatar
Default window switches
I have only heard of msd's, is there any others out there that are good, and about how much does the switch usually run?
Old 02-07-2004, 12:00 PM
Apollyon's Avatar
I have heard of the NOS rpm switch and a Mallory switch that people can use as a window switch. I had originally used the NOS kit on my 99 TA and had good results with it. I still have the kit in my parts bin in my room. The kit is #15879 and costs around $150-$200 new. I dont know much about the Mallory kit though. On my 2K vette I purchased the MSD window switch because its easier wiring up to the car. You can get these kits from $60-90 depending where you can find them. Hope this helps.
Old 02-07-2004, 12:09 PM
Apollyon's Avatar
Summit Racing has the Mallory Window Switch for $91.95 plus shipping, the part number is MAA-628. Jeg's said that the switch was discontinued by the manufacture so you might want to be careful and cautious with that switch.
Old 02-08-2004, 09:15 AM
5 Liter Eater's Avatar
What about the Harlan one?
<link removed>
They are $50 and do not require pills!
Old 02-08-2004, 10:49 AM
MT POKT's Avatar
We just installed the newer version "Timing Tuner". It hase controlls for timing advance and retard for the entire range, advance and retard for WOT that can be armed with your N2O WOT switch, and built in window switch that will operate N2O up to 6300 rpm. I originally bought it to retard the timing while spraying. After reading more into it, we ended up eliminating our MSD window switch. We'll have it on the dyno in another week or two and I'll post the results.
Old 02-09-2004, 11:10 AM
exodus's Avatar
thanks for the info. I think that I will stick with the MSD switch.
Old 02-10-2004, 11:57 AM
Ed Blown Vert's Avatar
I think Mallory is the best one. No pills. Too bad they don't make it anymore.
I was thinking about switching to the timing tuner, how you like it Greg?
Old 02-10-2004, 03:54 PM
MT POKT's Avatar
I haven't had the opportunity to use it yet. I'm waiting on the custom fuel rails to get done to finish the install. We'll have some serious dyno time soon as she's back together. We're looking for 600hp. If it does what it's supposed to it'll be awesome! I'll keep you all posted...
Old 02-16-2004, 10:47 PM
mikey94_95's Avatar
Lightbulb
I use a BMN window switch. Works great with LS1 cars utilizing 4-cylinder mode. The link is www.bmnracetech.com
Old 02-16-2004, 11:54 PM
Drake's Avatar
Harlan's window switch... no doubt about it.
