Does an 05 LS6 have floating rods?
Awesome, thanks dude!
New for 2005: "The 5.7L LS1 and LS6 V-8s are equipped with new floating-pin pistons. First introduced on GM Powertrain’s Vortec 6000 H.0. V-8, these pistons feature wrist pins that “float” inside the rod bushing and the pin bores in the piston barrel. Previously, the LS1 and LS6 used a fixed-pin assembly, in which the connecting rod is fixed to the piston’s wrist pin, and the pin rotates in the pin bore. Snap rings now retain the wrist pin in the piston, while the rod moves laterally on a bushing around the pin. The floating pins were introduced as an interim change late in the 2004 model year."
