BAD Missfire....
Old 12-23-2010, 12:00 PM
SpeedFreak123's Avatar
Default BAD Missfire....
Got everything back togeather after the head gaskets swap... Start it up, it has a bad missfire, the engine is rocking side to side real hard, and it sounds like complete **** and like it is choking when i give it gas.
The fuel injector might not be pushed all the way down (orange strip is still showing), could that cause a mis?
Maybe spark plugs are cracked, They were dropped a few times?
Any ideas?
Old 12-23-2010, 12:04 PM
VinR1's Avatar
sounds like crossed wires... like on the wrong plug
Old 12-23-2010, 12:34 PM
That's what I was thinking. We tried checking, drivers side looks good, but we can't see the opti on passenger side
Old 12-23-2010, 12:56 PM
More opinions.!!!!!.... I need it running ASAP!!!!
Old 12-23-2010, 01:10 PM
LSWHO's Avatar
I don't get it. You are looking for more things to check and you haven't even finished checking what you've been told to?
Old 12-23-2010, 01:55 PM
My car is at my cousins house on blocks. It has to be out of there tonight my uncle said. So i am trying to get a list of things to check so i can go over and if one doesn't work, I'll go to the next.
Old 12-23-2010, 02:42 PM
Forgot to mention that when it does start the oil pressure is above 80 on the gauge?
Btw, it doesn't want to start anymore, but has enough battery juice.... ignition right?
Old 12-23-2010, 04:21 PM
qc97z's Avatar
The questions you're asking indicate you have no idea what you're doing. Quit skipping around and let people give you answers.
1) If you dropped the plugs, replace them.
2) You must check ALL of the wires and make sure they're connected to the proper cylinders.
3) If your fuel injector isn't down all the way, then push it in the rest of the way (duh).
4) Check to make sure everything sensor-wise is hooked up (TPS, IAC, MAF, MAP, etc).
Old 12-23-2010, 04:23 PM
gorge's Avatar
opti opti opti, sounds like it took a **** on you
Old 12-23-2010, 07:32 PM
All wires are on correctly.
I got it running but it has a bad miss, still.
We ran the code and it said P0305 which is "cylinder 5 misfire" .
I pulled the plug, its fine.
Maybe the wires bad. ?
Yeah, your right I don't know what I'm doing, that's why I'm on here asking for answers.
Old 12-24-2010, 01:44 AM
qc97z's Avatar
How do you know the plug you pulled is fine? Just because it looks fine doesn't mean it is. Replace it just to be sure.
Old 12-24-2010, 01:49 AM
red93z28lt1's Avatar
here is what you do replace opti, wires, check wiring, plugs and then see if you still have a problem
Old 12-24-2010, 02:53 PM
gorge's Avatar
I had the same problem for 3 months, replaced fuel pump, fuel filter, spark plugs, spark plug wires, injectors, MAF, tuned it, didn't touch the opti, ended up trading the car in and getting a 07 cobalt so I can save some money and star from scratch and do **** the right way
Old 12-24-2010, 06:32 PM
We checked the wire with a Voltage Meter, it said 0 Resistance which is very uncommon, prob. a bad wire. We did have to tug on it pretty hard to get it from between the tubes on the headers.
The wire im speaking about is cylinder 5. Im going to try and replace that wire and see if it helps.
Old 12-24-2010, 06:34 PM
BTW, we got it running again, and ran the code while it was running and the SES light was flashing, and it showed P0305 "Cylinder 5 misfire".
Old 12-24-2010, 10:58 PM
melted wire grounded to the headers then right?
Old 12-24-2010, 11:06 PM
hitmanws6's Avatar
its your wire, thats the only thing that would cause it
Old 12-26-2010, 03:25 PM
gorge's Avatar
I got a set of MSD wires for sale, PN 32129 they are fitted to go over the valve covers probably about two months old maybe 200 miles on them, 100 bucks takes them, let me know if interested
Old 12-26-2010, 04:23 PM
tricked94camaro's Avatar
did you tighten your rockers correctly?
Old 12-29-2010, 11:30 PM
We tried the wire .. it was off a Chevy 350 with reg. distributor, we rigged uit up to make connection tho... didnt fix it.
My mechanic thinks the piston ring could be messed up???? ouch! Does anyone think its the ring?
Rockers were tightened down till the pushrod could spin in your fingers, then a half turn back.
Quick Reply: BAD Missfire....
