How would this cam perform in a NA motor 226/230 116+1
Im looking at buying this cam from a board member, It looks like it would be a nice sleeper cam and also give me a little more ptv clearance with the wider lsa.
the only thing holding me back is that it was spec'd for FI or Nitrous use. I was kinda looking for a sleeper style cam so would this work out well for me or will I be leaving a chunk of power on the table???
lift is .598 .600 there was a similar eps cam with stock 243 heads that put down 430whp through an auto. the specs there were 222/226 115. I figured with more duration and only one more degree lsa it would be in the same ballpark. I also have a set of 243 heads milled .025 I plan on using
