passenger door sagging
Old 12-28-2010, 04:06 PM
blitzace12's Avatar
Default passenger door sagging
my passenger door is sagging a little bit how do i fix this?
Old 12-28-2010, 10:00 PM
japsw20's Avatar
My car had the same issue when I purchased it, I thought no biggie probably worn out door pins. After inspection door was cracked, not the first camaro I see with cracked doors around the hinge area
Old 12-31-2010, 04:45 PM
blitzace12's Avatar
how do i replace a door pin? is there a write up or something that i could use? and i read that i should replace the bushings too. is this true?
Old 12-31-2010, 07:36 PM
BRUTL's Avatar
Door pins usually come with the bushings. Grab a floor jack to support the door, grab a small hammer and punch and knock the pins out. You're probably going to have to remove the door spring on the lower hinge, which you should get the special tool for. I believe Autozone carries them, just ask for a door spring compressor. Then knock out the bushings, tap the new ones in, and tap in the new door pins.
Old 12-31-2010, 08:33 PM
skimms98's Avatar
my door is cracked at the hinge area too....is there an easy fix? or at all?
Old 12-31-2010, 09:57 PM
venomblue550's Avatar
get a new door if yours is cracked
Old 01-01-2011, 01:17 PM
japsw20's Avatar
the door can be fixed, used doors are cheap but you will more then likely have to have it sprayed and blended into the car. Any GOOD body shop can repair your door.
Quick Reply: passenger door sagging
