1969 Camaro front disc brake conversion kits
If any of you have done a drum to disc front brake conversion, what kit would you recommend for the price? I have browsed Summit and Jegs, and it seems that $650-$750 is the norm for their conversion kits.
i got a right stuff kit from ebay for around 450-500.. some pic's of the install in my bild thread in my sig. It works well enough but now I am looking a c5 brakes for the front..but it means i will haqve to go to 17"s in the front and loose my stock look.
+1 on that. The Kore3 C5 caliper adapters in conjunction with stock C5 calipers/rotors work quite well. The only drawback is the 17" wheel requirement.
With patient, diligent parts searches , the caliper/rotor cost can be exceptionally reasonable. Replacement of the common wear items in the finished setup is hassle-free, unlimited and cost-effective.
I have the C5 brakes on a 68 Camaro. They work great. I have autocrossed it for 2 years, and they performed well. I have the hybrid kit on front. It uses a c4 rotor and a C5 caliper, I think it uses the speed tech brackets.the rear is all c5 from Kore 3. I had about 650 in each end.
I can save You some money compared to Jegs and Summit on these kits, it wont be a tremendous amount but it will be worthwhile. More importantly I can offer personalized service before and after the sale.
Let Me know if You would like to discuss the kit best suited for You.
Thanks,
Carl
Yeah I know the C5 stuff is awesome, but I don't want to have to put 17 or 18" wheels on. I'm sticking with the stock rally wheels. I will probably get ahold of Carl@CRP when I'm ready to order.
