1.8 roller rockers
When I did the retinue after the install, had to add ~5% to the MAF curve. That should translate into 15hp +/-. Not really a startling change, seemed affect the top end more, so the power came on progressively through the run.
I put in new valve springs at the same time, and bumped shift points closer to 6500. Pulls to redline.
I can't really talk about the difference those alone made, cause I had my headers put on at the same time. With both mods done though my def pulls harder up top when cruising, and blows the tires away from a dig even more so than before.
Not too much to report; still not tuned, N20 still not complete, small issues to deal with (no remote start or cruise control). Weather has been too cold to make any video runs. If the temps move into the 40s then I will be able to post up a video.
this is going to sound really stupid but it happend to me in my o4 gtp comp g check the third brake light in the spoiler they come unpluged
http://intense-racing.com/Merchant2/...LSx_Valvetrain
i bought those, IMHO the HS rockers are overrated.
keep the cranes in the basement and buy a set of comp cam ultra golds they are the best money can buy and my second choice would be the harland sharps
i have used the cranes before and they are ****
when you think about crane remember the 80s when they where known for wiping the lobes clean of a cam and they went belly up, im just saying
