View Poll Results: Which top end?
better cam and home port the 799 I have already bought
1
25.00%
keep my cam and buy ported TFS 220 heads
3
75.00%
Voters: 4. You may not vote on this poll
TFS 220 (cleaned up) vs home port 799
I have a pair of 799 heads I am planning to mildly port/mill and put on since I got them for a good deal.
But I was just offered a pair of TFS220 heads lightly cleaned up by what I would call a professional since he does work for a Houston area shop. Said they flowed 330cfm @650 lift.
Obviously the TFS heads are going to be superior...but it is my understanding it would be strongly recommended I use aftermarket roller rockers on those heads...which would absolutely put them out of my price range.
My current cam won't be a good match for either set of heads really, so I was considering a swap to something different in the low 230s with newer lobes (likely EPS) which I also wouldn't be able to afford with the other heads.
So basically it would look something like:
better cam/799 (sell stock heads and current cam, more money in my pocket) vs. my cam/TFS heads (sell stock heads and 799)
I bet those TFS would pick up 20+ pretty easy.
I had a set of CNC'ed 5.3's and picked up 19/19 on back 2 back dyno runs when I switched to TFS 220'S on my old 346... I am sure they are worth more than that on my new setup.....
According to Brian Tooley of Total Engine Airflow you can swap out the bronze valve guides with powdered metal valve guides and run OEM rockers with the 220s. I don't know the cost, but it might provide another opiton to consider.
https://ls1tech.com/forums/14109610-post32.html
Poolfanatic, with some MTI 2E LS6 back in the day and a X1 made 445rwhp and it was tuned safely with spray.
Bshell with a TR230 and TFS 215 made 460+RWHP..
