View Poll Results: Which top end?
better cam and home port the 799 I have already bought
1
25.00%
keep my cam and buy ported TFS 220 heads
3
75.00%
Voters: 4. You may not vote on this poll
TFS 220 (cleaned up) vs home port 799
Old 01-04-2011, 03:40 PM
thunderstruck507's Avatar
Default TFS 220 (cleaned up) vs home port 799
I have a pair of 799 heads I am planning to mildly port/mill and put on since I got them for a good deal.
But I was just offered a pair of TFS220 heads lightly cleaned up by what I would call a professional since he does work for a Houston area shop. Said they flowed 330cfm @650 lift.
Obviously the TFS heads are going to be superior...but it is my understanding it would be strongly recommended I use aftermarket roller rockers on those heads...which would absolutely put them out of my price range.
My current cam won't be a good match for either set of heads really, so I was considering a swap to something different in the low 230s with newer lobes (likely EPS) which I also wouldn't be able to afford with the other heads.
So basically it would look something like:
better cam/799 (sell stock heads and current cam, more money in my pocket) vs. my cam/TFS heads (sell stock heads and 799)
Old 01-04-2011, 03:55 PM
SOMbitch's Avatar
I bet those TFS would pick up 20+ pretty easy.
I had a set of CNC'ed 5.3's and picked up 19/19 on back 2 back dyno runs when I switched to TFS 220'S on my old 346... I am sure they are worth more than that on my new setup.....
Old 01-04-2011, 04:09 PM
So you're saying 20+ over the 799 (same as 243 ls6 castings)?
Right now I have stock 99 ls1 heads...I would hope to get at least 20+ RWHP from the 799s milled/mild ported.
Old 01-04-2011, 04:45 PM
Darkman's Avatar
According to Brian Tooley of Total Engine Airflow you can swap out the bronze valve guides with powdered metal valve guides and run OEM rockers with the 220s. I don't know the cost, but it might provide another opiton to consider.
https://ls1tech.com/forums/14109610-post32.html
Old 01-04-2011, 05:35 PM
SOMbitch's Avatar
Obviously the parts you pair with the heads will affect results but yeah I can see those TFS heads making 20 over mild 799's and 40 over unported 853's very realistically....
Old 01-04-2011, 08:14 PM
TXZ28LS1's Avatar
Thunderstruck, i would just take the heads you have and send them to TEA or Livernois motorsports for some work. I also have my reverse split, and as much as i am considering aftermarket castings like AFR, it seems like the best results with a reverse split cam with an LS6 head. I also will throw on a ported fast 92 intake and see how far i can push this cam.
Poolfanatic, with some MTI 2E LS6 back in the day and a X1 made 445rwhp and it was tuned safely with spray.
Bshell with a TR230 and TFS 215 made 460+RWHP..
Quick Reply: TFS 220 (cleaned up) vs home port 799
