6.2L, L92 CNC, Victor jr, Carb., CAM RECOMMENDATIONS?
Old 01-04-2011, 09:11 PM
427cidLT5's Avatar
Default 6.2L, L92 CNC, Victor jr, Carb., CAM RECOMMENDATIONS?
Haven't bought any parts yet but have a new 6.2l engine L92 heads, leaving bottom end stock.
Going to send the heads out for CNC porting/milling or buy a set outright, going with a 850 carb., staying with hyd roller. rev to 7000. Automatic car for drag race application.
Cam, head, intake recommendations?
Have some ideas, just seeing what has worked for some that have been running the L92s.
Thanks
Old 01-04-2011, 10:35 PM
raymond mckinney's Avatar
I hear the Tsp 231/236 cam on 111lsa works well with single planes.
Old 01-04-2011, 10:48 PM
68 SS's Avatar
I have a set of TSP CNC'd L92's with the good PRC dual springs that will be for sale soon if you are interested. Heads only have 1200 miles on them worked great, I am going FI so had to make a change.
Old 01-04-2011, 11:42 PM
hymey's Avatar
Id be going something on 108 if u flycut around 236 intake lobe and ten degree split 4 degrees advance 104 icl
Old 01-05-2011, 08:15 AM
crossbreed383's Avatar
i have a nice cam for ya
255-263@050 -632 lift hyd roller- custom built by me and billy at comp cams for me
110 lobe centers w 3 degree advance built in to it on a very stable lobe core that will turn 7500 rpm easy with a good dual spring set up
can also be ran with solid lifters if you want
never ran this cam as i went to a true solid roller
new in box
$300 shipped
Old 01-05-2011, 09:15 AM
No way a 255/263 .632 cam will fit in a stock bottom end milled headed l92. Ask me how i know! lol
Old 01-05-2011, 09:23 AM
bozzhawg's Avatar
x2 definitely not with a stock bottom end, flycutting would not even be a choice...... it would be a grenade .....
Bozz
Old 01-05-2011, 01:26 PM
how large can you go with flycutting?
Old 01-06-2011, 04:06 PM
427cidLT5's Avatar
Thanks for the tech guys....The 6.2 is going in a customers '55 T-bird, wants to drag race it.
Heres the last one we built..LS7 with a dominator, sheet metal intake,diamond pistons... fits in the '40 Ford Coupe real good
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 01-06-2011, 04:08 PM
Nice build! Should make 570 plus hp with the tsp cam.
Old 01-06-2011, 04:25 PM
IDRIVEAG8GT's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
OOOOOHHHHH. Dats purdy.
Old 02-03-2011, 06:54 PM
hymey's Avatar
You might get away with a mid 230s intake without flycutting, But you want compression too? I'd go something like a 240-250 on 108 with 11:1 and flycuts. 110-112 stuff is a wide lobe sep for single plains. I run 110-112 on plastic intakes 108 on the single plain with a 240s intake.
Old 02-03-2011, 08:49 PM
dwill73's Avatar
new in box
$300 shipped
This would work.
Old 02-03-2011, 09:49 PM
aww hell
Rods to big a puss to put a real cam in his engines
lol
Old 02-04-2011, 05:50 AM
odarabla's Avatar
Best thing you can do is get a custom cam cut for your appilication to be sure that all your parts are working together. I just had Goeff at EPS cut a custom cam for my 402ci. Be sure to have all the information about your build and your car handy so he can be spot on with the specs.
Old 02-04-2011, 08:28 AM
dwill73's Avatar
X2, nice to hear I'm not the only one to put a 108 LSA on a Ls single plain carb motor.
Old 02-07-2011, 11:21 PM
driver56's Avatar
I just finished a carb'd 402 with around 12.5:1 compression, a single plane, and a custom spec'd COMP solid roller on a 106lsa, 256/262 @0.050 with 0.690 lift. Motor makes all the right sounds.
Old 02-09-2011, 07:43 AM
dwill73's Avatar
Sounds good to me.
Old 02-09-2011, 07:52 AM
ls-won-84c10's Avatar
Default heads
im intrested in those heads..... how much?
Quick Reply: 6.2L, L92 CNC, Victor jr, Carb., CAM RECOMMENDATIONS?
