Hollow/Sodium filled valves?
yeah if i'm not mistaken it was only the c5z's that had the sodium/hollow valves. i may be brain farting but i can't think of another...
edit: can't remember if the cts-v's had them or not.
What Darkman said. The 243's obviously came on the LS6 and the LS2 but the only heads to get hollow/sodium filled valves were the ones bolted to the LS6 including the 04-05 CTS-V. The 06-07 had the LS2 and they did not have the hollow/sodium filled valves. So if you find a set off a V, find out for sure what year they came off of. I do not know how to tell the difference just by looking. I have a set of the hollow valves in my garage that are bad. I broke a rod and kissed a piston. Found a whole set on here brand new for less than one valve from the dealer. I can tell you they are ridiculously light.
