Clear Corners
Clear Corners
Anyone know where I can buy clear corners that actually fit?? I've got two sets from eBay and they both are too wide and not long enough.
Also I've heard of switchback LED's for the clear corners and want to get them, but it seems like I need other parts to make them flash right and it's confusing on the website.
What else do I need to get for the switchbacks to work right?
Thanks guys!
Thanks guys!
All of the clear corners can either be purchased at one of our many sponsors >>>>>>>>>
or on ebay. The depo corners seem to have the best fit and they tend not to leak like the other brands.
These are them
http://cgi.ebay.com/ebaymotors/1993-...Q5fAccessories
Regarding the swicthbacks, you will need the electronic flasher to get them to work properly and avoid the hyperflash symtoms. You could also use the resistors to get them to work but the flasher in my opinion is better than using the resistors.
These are them
1 Post
I have gotten 2 sets off ebay and they both are/were fine other than the bulb sitting to far back and melting the back part of the housing. I just ordered another set cause I have LEDs in the old ones and I wanted to make sure they didn't do anything before I ordered another set so I wouldn't be in the hole. As far as the switchbacks, use the search up top cause I think there is a right up on them.
i ordered smoked corners for my LT1. Fit fine for me, only downfall was that the plastic is starting to turn yellow. I have clear corners on my LS1 and had to remove the front fascia to get them to go in all the way. After that it was fine.
I replaced the stock amber corners with these:
http://cgi.ebay.com/ebaymotors/93-02...ht_3502wt_1163
Then switched to these after a short period of blacked out ones. I like these ones more than the first set b/c the reflectors and clear lenses match the headlights better:
http://cgi.ebay.com/ebaymotors/CHEVY...ht_4477wt_1163
Both fit well and did not leak at all. What Guz said on the switchbacks. You will need one of those options to make them work right.
I did but it seemed like the housing was too long and was hitting where the fascia meets the bumper. It's not hard to take it off, 7 or 8 clips if i remember
