Trans Am Dash Pad Interchangeability
Old Jan 5, 2011 | 11:06 PM
MattSapp95_T/A's Avatar
Default Trans Am Dash Pad Interchangeability
Ok I have a 95 Trans Am... I need a new dash pad..
I DO NOT have heater or AC in the car so I could care less if the vent on the dash pad lines up I just need to know if 97 and up will actually fit in mine? They are a lot easier to find than 93-96 pads...
I have did a search and get mixed answers...some say yes no prob just the vents and security light hole is different...others say that they are completely different...So hopefully someone can give me a firm answer so I can get one ordered...
Thanks
Matt
Old Jan 6, 2011 | 09:28 PM
No one knows??
Old Jan 6, 2011 | 09:43 PM
Raleigh TA's Avatar
These are pics of covers, but they show the differences:
97+
93-96
Old Jan 6, 2011 | 10:03 PM
Trans Am Jam's Avatar
dash pads are wack. just be a little creative and make something 10000x better.
Old Jan 6, 2011 | 10:50 PM
VinR1's Avatar
That's not a 93-96 pad. The difference is the corner where the top of the pass airbag meets the section above the center vents. The earlier pad is like a Z with sharp corners whereas the newer is more rounded like a S. They'll swap but won't match up in that one spot
Old Jan 8, 2011 | 01:55 AM
97+
93-96
Mine is a 95 and it does not look like that at all...I think that bottom one is for a camaro or something... mine does not have that sharp point by the center vent mine looks more like the top one...
when I say dash pad I am not referring to a carpet dash pad...I am actually talking about the plastic piece of the dash that usually cracks....
Mine doesnt have sharp corners though?? maybe that is only for the camaro?
Old Jan 8, 2011 | 06:21 PM
Raleigh TA's Avatar
I believe there are only two dash covers for 4th gens. One with the point in the middle from earlier 4th,
and one from later
I know that at least for the late 4th gens, Firebirds and Camaros use the same dash covers. I have replaced two cracked Firebird ones with salvaged ones from Camaros.
Old Jan 8, 2011 | 08:16 PM
TechCam97's Avatar
As far as physical interchangeability, dash pads from 93-02 Firebirds and 97-02 Camaros will work. 93-96 Camaros have a completely different dashpad that doesn't interchange with ANY Firebird, or 97+ Camaro. The main difference in the 93-02 Firebird / 97-02 Camaro dash pads are the colors. 00+ Can come in ebony or graphite. 93 to 99s had graphite.
