What injector for 415 stroker
Looking for some suggestions on what type of injector to run. Looking for ease of tune, lbs, Hi or Low Imped, pintal or disk injectors and 07% - 80% DC.
I am hoping for low to mid 500hp @ the wheel and will be using a Vic Jr setup, Speed Density tune, 2000 ECU.
DM
DM
http://www.corvetteinjectors.com/sho...p?productid=38
you need to run a 50lb@58psi.this will keep your dc around 75%-80% leaving you some room to grow. you want to stay with a bosch high imp.these are very easy to tune.
DM
