MSD 72lb Injectors on 346NA, Will these Fit LS1 Rail?
My friend has a SUPER SUPER deal on some Brand New un-opened
MSD 72lb/hr 2ohm 4/1A #2014 Injectors, I can have all 8 for basically $200.00.
I have a 346NA set-up, and understand a 72lb injector is stupid big for what i'm running... 2 questions:
*Will it take my Tuner a ton of time to fix the fuel tables as these injectors are such a huge difference than the 26lb'ers I have now?
*Will Idle/low speed driveability be much worse, or are these injectors just not big enough where this issue would be a problem? if this doesnt make sense... Example: 2000cc Injectors will make an import car idle like **** because even though the injector "on-time" is lowest possible, there is still to much fuel being injected for idle.
I understand these injectors are overkill, just need to know basically if they will fit and if so if they will be problematic for my car and tuner. Thanks!
Link to said injectors: http://performanceparts.com/part.php?partID=186049
