Pull fuses to prevent engine startup?
To prevent the engine from starting and the alarm still function.
Should I pull the PCM BAT and PCM IGN fuses while the ignition is off? Just want to add some additional temporary security.
Because if you have a engine full n2o you do not want the engine to fire. pulling the fuel pump fuse would keep it from cranking up but the spark plugs would continue to fire and kaboom
