general opinion about engine, head, cam combo
i would like peoples opinion about an engine, head, cam combo.
heres the rundown.
2004 lq9 26439 miles on the short block, arp connecting rod bolts.
cast# 853 ls1 heads ported w/ ls6 beehive valve springs, 7.450 push rods, stock lq9 rockers and valves, arp head bolts.
schneider racing cam .540 lift, 284/294 duration, 114 lobe separation
edelbrock pro-flow xt intake manifold , matched pro-flow fuel rails w/ 39lb injectors and a 85mm cable actuated throttle valve.
with this set up does anyone know a rough hp numbers?
could i go up to a .575 lift cam and achieve better hp numbers?
this is all being backed up by a 6l80e trans.
heres the rundown.
https://ls1tech.com/forums/generatio...od-length.html
Check this post out and it will tell you how to check. Its always a good idea to measure so you are 100% sure. You dont want your valvetrain clicking and clacking or worse... tearing something up.
do you valve springs meet the spring pressured need for the cam you listed ?did you buy the cam yet?would you buy better springs to work with a different cam?what do your heads flow ,cfm.there are a couple people on this forum that with spec a cam if you give them enough information.
i actually have the cam already but its not installed yet. i decided to go to a larger cam and with that will have to get different springs along with pushrods.
as with the other setup i have. the pushrods are the exact correct length for this particular cam the measurement was done prior to me purchasing them for an identical build done a few months prior. With preparing for that cam i had the comp ls6 beehive springs installed in my heads.
i have no flow numbers as i have no access to a flowbench. so i just have to deal with that portion of the build having full trust in the guy doing the work on the heads.
i would like to find a strong combo with retaining the factory rocker arms.
im thinking somewhere between .570 but staying below the .610 lift mark.
by going to a different cam where would be an advisable setting for my rev limit?
would this cam work for me?
https://ls1tech.com/forums/parts-cla...230-238-a.html
any info would be greatly appreciated. thanks guys
