2009 5.3&4l65 wiring... stock fuse box?
Greetings everyone
Im swapping all the stuff from a 2009 silverado to my fox. Since Im a little supid with electronics and wiring . is it easier just to run the stock fuse box and then turn off al codes that appear on the missing citcuits?
Or please tell me which cirtuits should I remove to keep it w0rking... I have been reading the web LT1SWAP( all the stuff about finding the orange wires and gorunds), but it doesnt use a car that retains the electronic transmision... the only one I have figured to keep is the one that tells the pcm when you press the brake.
thanks for your help
I kept the under hood fuse box on my swap, yours is 10yrs new but they are probably about the same. Its probably not as clean as reworking the harness but I think it looks ok. You only need to hook up whats shown on lt1swap and it should work.
